1 - 19 of 19 Posts
99% of the time my Xb sounds like it isnt even on and is nice and quiet
but 1% of the time the engine will do a little shaking nothing much but enough to be noticed
the equivilent of someone in the passengers seat nervously out of habit shaking thier leg.
I only have 250 miles on it is this normal or should i have it checked out
i also might add its mainly when stopped (in drive brake applied) or idle
:confused:
mine does it too, kinda like when you turn the A/C on. just a little shake.
I think it is normal mine has just over 10,000 miles
At idle, sitting in the drive thru, etc.
I just took mine in for the 5000 mile oil change yesterday and I asked the service manager about it, he said it's normal. Then he told me it would cost me 280 to diagnose why my A/C isn't working since I have added a ground wire kit and an aftermarket stereo. They decided it isn't a warranty covered item just by "looking" at it. :mad:
Oh no its going to blow! :rolleyes: :D
Its normal. The xb has a rough idle, and when you turn on the a/c you will notice the rpm's at idle will boggle, then resume to where it was originally. If you sit in traffic for a while, you will also notice a slight "rumble" as well.
Fix? Synthetic oil. You still will occasionally get the "rumble", but it will clean the idle up a bit.
mertechperformance
they are cheaply made light cars. imagine if u ad an engine damper like me. lot more. it's normal.
Exactly. If you take your front bumper off for example, its light and theres nothing there. Part of the reason why when you idle for a while the front shakes. The dashboard and everything is light weight, extremely light compared to majority of cars. Small price to pay to be light weight. :D
Premium Member
Take off the ground wires and go to a different dealer, then put them back on after they fix it under warranty. That might work. :)
mertechperformance
i have the weapon r damper . it's not too bad but my car is slammed , and it's cheap i never expected anything smooth or luxurious so yea , it's faster than most others so i'm pretty decently happy with it. just turn the stereo up .
and on the neutral bit if you've got a manual it's wise since it will save you a throw out bearing or two , especially if ya have a racing clutch like I do .
throwout bearings do not like when you hold in the clutch constantly (like at a red light)...then you get that nice grinding noise while driving down the road :eek:
That's what I was thinking and as soon as I'm done with the bought of pneumonia I'll do just that!
1 - 19 of 19 Posts
