1 - 5 of 5 Posts
Easy. One location. No splicing.
Electricity Electronic engineering Electrical wiring Electronic component Computer hardware
I am using the switched power from IGN 2 to fire two relays
to interrupt the two headlight fuses that drive the big relay.
This was my prototype. Will remake with neatness later.
Minor mod in the cover needed.
The two relays fit neatly into the pockets next the relays.
Will make or find a proper chassis ground point.
Oh!
That the headlights stay on when the ignition is turned off.
I often leave for work in the dark and arrive when the sun is out.
That and I am an idiot.
I need to choose an ignition dependent pwr source for my fogs. I just did easy way out and used a chassis ground so they work any time. But have left them on several times for like a day and a half. Luckily they are LED and car started like nothing happened.
1 - 5 of 5 Posts
