1. First of all you need to remove the two bolts holding the seat down in the front. These pass through a mounting bracket, you cant miss them.
2. Next, we will want to pull the front of the seat up to change the angle but to do this you must loosen the bolts that anchor the seat in the back. You must take off the cover to get to them but once again, you cant miss them. After doing this you should be able to life the front of the seat up and now you can see where we are going with this.
3. Next you must go to the local hardware store and buy new longer bolts and some washers. I went to lowes first and like an idiot bough standard bolts and of course they didnt fit so i had to return them and go to home depot because lowes had like 7 items that were metric. This next part will depend on the person but i got new bolts that were 10.25x50mm. Try to get the strongest bolt you can, preferably grade 8 so you they can withstand an impact. Also, you must buy washers. These will go under the mounting bracket in the front. I used 10 under each bracket but i suggest starting at 5 and then working your way up. This allowed for a pretty big increase in the angle and comfort of the seat.
4. Now just slip the washers under the mount and slip in the new bolts. Visually, you should already see a difference so tighten up the bolts in the front and back, replace the back covers and you are done.
5. Test out your new seat and enjoy the comfort!
