1 - 4 of 4 Posts
Hello I have an 04 xb got a replacement lock cylinder,key is still not releasing out.anyone have the same problem and figured it out.any help will be greatly appreciated.
xB Leaving Pit Soon
If you have an automatic xB, check the ignition switch key release cable adjustment.
The cable runs from the steering column to under the floor console; and is located on the driver's side of the transaxle selector. Make sure the cable moves freely with the selector. Adjust the cable length to allow the key to reach the LOCK position on the steering column and to be removed. The circular adjustment knob surrounds the cable housing.
Good luck with your task.
1 - 4 of 4 Posts
