1 - 3 of 3 Posts
ok just got home from work and turned the ignitiion off, and my radio didnt go off so i started the car back up and tried again, and it still wouldnt turn off. i have had my kenwood cd deck for almost a year now and havent had this problem what do you think it is.. thanks
jeremy
If you're absolutely sure you didn't cross the 12V memory and the 12V power wires when you installed it (assuming you used an adapter for the wiring harness) then your best bet is to get the diagram for the pinouts for the radio side of the harness adapter. Use a mulitmeter (available at any Radio Shack for a cheap starter one) and check to see if you are still getting 12V on the power pin when the ignition is set to off. If you are, it's an issue with the wiring. If you aren't it's an issue with the radio. Hope that helps.
1 - 3 of 3 Posts
