81 - 83 of 83 Posts
Discussion Starter #81
Also,
Sat/Sun 4/25/20 - 4/26/20
207,732 Miles
I replaced the driver side drive shaft and seal that goes on the trans.
Not sure of the brand of the drive shaft, just one I got from Napa.
The part # is in the pics for the seal. For Manual Trans.
Also drained the trans fluid and refilled it.
2 quarts Royal Purple 75w90. Forgot to take a pic so just adding a stock pic of it lol
Discussion Starter #82
Also, Also, lol last one.
207,732 Miles
I wanted to replace the drivers side ball joint as I also had replaced the pass side ball joint a few years back. I somehow ended up messing up the control arm when I pressed the old one out, or when I pressed the new one in as the new one fit loose. So now I had to replace the drivers side control arm. But got it replaced. 3rd pic is of new control arm and it already comes with a ball joint so that was good! Not sure of the brand, but I got it from O'reillys as that's the only place that could get it for me that Sat. Now I need to get an alignment as it pulls to the left a little. Not too bad and can still drive it. Also saw that I need new brake pads, so will probably be doing that next weekend.
Discussion Starter #83
Fri 6/5/20
208,875 Miles
Replaced the alternator and belt. Just got them from O'reily Auto Parts. Gonna try and see if I can get the original one (Denso) rebuilt.
81 - 83 of 83 Posts
