1 - 4 of 4 Posts
I just picked up a pair of rotors from a friend and I dont know how to install them. Anyone have any knowledge of it ?
Basically you have to remove brake calipers, then swap out the discs.
If they seem stuck, just tap them gently (and I mean gently!) with a dead-blow mallet or something like it. They'll come right off!!
Which rotors did you get?
its a fairly easy process, just remove the caliper then the piece that your brake pads go into. if it is hard to remove you can tap it or you can use a bolt and screw it in through one of the holes on the stock rotor and it wil come right off. when you take off the calipers do not disconnect the brake fluid line or you will have to put in more brake fluid and bleed the system. hope this helps.
1 - 4 of 4 Posts
