1 - 10 of 10 Posts
Here are the procedures to manipulate the remote door lock system. As you can see they are hardly difficult programming exercises. Any competent mechanic should be able to do it in 20 minutes including time for paperwork, coffee, sharing a dirty joke with the next guy, and a cigarette break. Competence, in this case, means the ability to read and follow instructions, not even knowing anything about cars.
As with anything, try these at your own risk. If you accidently reprogram your engine to produce 200HP don't blame me!
There are four different modes you can use to program remote door lock functions.
Confirmation mode allows you to check the number of transmitters recorded.
Add mode allows you to add a transmitter without disturbing existing transmitters.
Rewrite mode allows you to replace all existing transmitters with new ones.
Prohibition mode erases all transmitters and turns off the remote door lock function.
Confirmation mode. To check for the number of remotes programmed into the car:
Start with the key out of the car, driver's door open and unlocked.
1.Insert key in ignition and pull out
2. Within 5 seconds, insert the key in the ignition and pull out again.
3. Within 40 seconds, close and open the driver's door twice, then insert and remove the key from the ignition again.
4. Within 40 more seconds, close and open the driver's door twice, then insert the key in the ignition and close the driver's door.
5. Turn ignition switch from LOCK to ON to OFF three times, leaving the key on for one second and off for one second each time.
6. Remove the key from the ignition lock.
The doors will lock and unlock themselves at about 2 second intervals. The number of times that the doors lock is the number of remotes that are programmed into the car. If the car locks/unlocks 5 times, there are no codes registered.
Add mode. To add a remote without disturbing existing remotes:
5. Turn ignition switch from LOCK to ON to OFF, leaving the key on for one second and off for one second.
The doors will lock and unlock themselves once.
7. Within 40 seconds, press the lock and unlock buttons on the transmitter at the same time and release.
8. Within 3 seconds, press either switch and release.
The doors will lock and unlock themselves once if the registration was successful. They will lock and unlock twice if the registration failed.
9. If you have other remotes to program, go back to step 7 within 40 seconds.
10. Insert the key in the ignition or open a door to complete registration.
Rewrite mode: To erase all remotes and add new ones:
5. Turn ignition switch from LOCK to ON to OFF twice, leaving the key on for one second and off for one second each time.
The doors will lock and unlock themselves twice, indicating that you are in rewrite mode.
Prohibition mode: To erase all codes and disable wireless door lock function:
5. Turn ignition switch from LOCK to ON to OFF five times, leaving the key on for one second and off for one second each time.
The doors will lock and unlock themselves 5 times at about 1 second intervals.
Discussion Starter #2
I have recently purchased my second (keeping first, not replacing) XB RS# and was able to program all 3 remotes to work on both carsin less than 15 minutes. My next step is to replace lock cylinders, or cut new keys with a car on each side, so that I have 3 sets of keys that work in both cars (no more guessing which set is for which car, or changing keys when changing cars, or needing extra keys or remotes on one keychain)
Thanks for the info, will it work with the way cool keys that have the lock/unlock built into them?
Discussion Starter #5
I'm not familiar with the "way cool keys" that you speak of.:confused:
Sorry I have no further info.:(
I think they are factory on TC's. They have the buttons on the key itself.
Discussion Starter #7
I know these work well on XBs, haven't tried them on TCs
And my mom said playing video games won't help you in the future...I mean its like doing codes for King on Tekken 5...
Oh and i think those "way cool keys" are the scion security keys...the TC i was lent from the dealer had one...
WoW old post. Good information on here, however, what is a good place to order a replacement remote? Obviously the dealer or eBay, but I'm thinking an online store that sells Scion parts would have them...Anyone? My dog got a hold of my remote and chewed it all up. :mad:
Discussion Starter #10
Yeah, you can get them almost anywhere
1 - 10 of 10 Posts
