1 - 12 of 12 Posts
I need toi remove the tail lights and I dont want to breeak or scratch something! doing this as Im typing also If I remove the lenses in the oven @ 250 how do I put the lenses back on? thanks so much in advance!
Theres 2 10mm nuts on the insde (remove the panel next to the rear speakers) Once off just wiggle the tails off untill you can see the plug then use a flat head screw driver to pop the plug out......I just did this about 30 min ago......first coatof paint on and waiting for dry time to put on the 2 and 3rd......I'm doing the paint on the outside version.....pics to come once complete.....................As for removing the lens use the search and try everything you can think of..............
....Happy Modding.........:D :D :D :D :D
I tried to wiggle the tail light out and the damned lense came off instead and it cracked are you sure theres no nuts or bolts holding them in?
To put the lens back on the panel just push them back on, the tabs will lock into their holes.
I'm fast in a slow way.
hey...if you broke yours, I have a set of painted ones I just took off...in perfect condition, just no reverse or turn bulbs
Theres 2 10mm Nuts that have to be removed from inside the car
skids said:
thanks eticket I must have missed the nuts comment
A strong life lesson, never, ever, miss your nuts! :eek:
1 - 12 of 12 Posts
