1 - 4 of 4 Posts
has anyone wired a set up i has no idea what the plug with the red wire and the plug with the white wire go. neither plug into the factory fog switch so i'm lost
thanx for any help
I'm just guessing but you may have to wire-tap into the harness......I had to do the same for my turn signals.....unless you can find an adapter to plug into the stock harness.
thats what i am guessing, i think the white is to illuminate the switch and needs a source power and the red wire is to power the fogs and needs a constant the kit has it's own switch and relay, looks factory too very nice just need to figure out how to wire it
well just incase anyone was wondering the red wire is ILL. for the switch and is power for the relay then the white wire is constant power for the lights
1 - 4 of 4 Posts
