1 - 10 of 10 Posts
ok so maybe im retarded but i just bought some nrg projectors which are way better than the ebay knock offs. but anyways i thought it would take me 20 minutes or so to install my headlight but then as i got into it i started to realize that it looks like you have to take off the bumper to take off the oem. is this true. could somebody give me a walkthrough on how to take of the oem headlights
Yes, you have to remove the two 10mm bolts under the front grille, and the two 10 mm lower bolts from the front fender. Place a blanket on the ground and gently let the front bumper cover hang. The bolts on the headlights are 10 mm also.
thats what i thought i just thought it was alot of work and wanted to make sure cuz ive never seen a car that you have to take off the bumper to get the headlights off but thank you
It's really easy, takes about 10min to get the bumper off. I did mine again today.
That front end is just schweeeeeeeeeeeet!
surfcitylocal said:
This might make it a little easier, I just did it last weekend.
http://www.clubxb.com/forums/f29/955-bumper-comes-off-easier-when-you/
I bought some projector lights myself. I did not realize you had to take all of this off just to install these lights. Got a question, my lights also have 3 other small bulbs across the bottom and there and additional 4 small wires for these as well. How and where do i connect these so that they will come on when i turn my lights on???? HELP!!!!!
thanks for the help guys it took no time to install once i took the bumper off. i think my lights look nice as hell now all i need to do is get my hood and rims. randkgifts i believe you have to hook up those wires to the parking light wire which i think is the blue wire. ill be sure to put up pics of the ride as soon as i get chance
1 - 10 of 10 Posts
