You beat me to it. Yeah, it sounds like your ground isn't very good, or you have wires touching, so its grounding out. Either way, it has to be something to do w/ ur ground.Frogbox said:I would check the ground, especially on the "dim" side.make sure you have a good one, scraping any and all paint and cleaning any oil/contamination off.
You might try adding a ground dedicated to that side for insurance.
no, its not suppose to. the high is sucking some from the low, meaning its shorted somewhere. you might have to check the wirings between the two.BATComm1 said:And..is it normal for the high beam lights to glow ..just slightly..when the low beams are on ???
