It's straight forward an easy. Pull the boot for the wiring back to unplug it, you might need to drop the headliner in the rear to access the plugs. Unclip the struts from the hatch then take out the two bolts on each hinge that hold them to the body. Make sure to have someone else with you to hold the hatch while undoing the bolts. It can be done by one person but is a lot easier with two.
