1 - 15 of 15 Posts
Okay, I've been told different things about what I should do about aligning my xb. I installed tein s techs and my camber is off on the front and rear (the rear is worse then the front). I talked to an alignment place and they told me to purchase a camber kit. I already have 10mm spacer shims on the rear (is this going to effect anything?) I basically just want to know what kind of camber kit I should purchase?
SPC makes a front and rear kit, to fix camber. Island Motor Sports has them in stock. (714) 522-7457. Your alignment guy should know what to do with them.
ok i have the same prob i have to buy new tires cuz the tred is worn to crap and i had the tires maybe for 3 mounths at the most will that help me even tho im on hydros or no
Um im not sure if it will help in your case if your on hydros. With hydros, you are constatly changing your ride hight which affects the alignment and etc.
There's a rear kit out now!?!
I'm running Cusco cambler plates up front. The rear sucks cuz of the fixed beam axle.
Anyone ever heard of Ingalls camber kits?
ingalls and SPC are both very similar in quality. for our cars however, there really isn't much to the camber kits. the fronts are a cam bolt and the rear are shims or adjustable shims depending on what kit you buy.
I bought the adjustable rear ones so we'll see how that goes when it comes in next monday.
adjustable for the rear??? how much can you get out of it?
I think I read somewhere as much a -1 for those adjustable rears. It's mostly just for alignment purposes.
1 - 15 of 15 Posts
