I was driving "The Green Box" and the OBD
Monitor Alarm went off!
The Cooling system Temp was higher than it should be.
www.clubxb.com
I found a crack in the Radiator Cap Housing!
I was debating about attempting to patch it up,
but decided to see IF it was available aftermarket.
And it is!
Dorman 902-679
The fact that it is Available in the aftermarket
SHOULD suggest there is a NEED for it!
I briefly considered taking one off the In-Op RS 1,
but decided to get a new one.
After installing a new one on the Green Box,
I got around to Checking the one on the RS 1.
Low and behold, IT is Cracked in the SAME area as well!!
And THAT is most likely WHY I ended up buying the Box!
Because it over heated and blew the Head Gasket.
So That makes a 50% failure rate (so far) in my xB Fleet!
So you have been WARNED!
Cooling system problems can cause engine failure!
The Sooner you can detect a problem, the better chance
of keeping your Box out of the Grave yard!
OBD port engine monitor
Has anyone used an OBD port engine Monitor? Something like this: https://www.amazon.com/KONNWEI-Automotive-Computer-Speedometer-Temperature/dp/B08GYLXJ1V I think I need something like this.
And it is!
Dorman 902-679
