You can see the one's I used to have mounted in my user profile pictures, and they were very easy to install and make. All you have to remove are the two side panels of the lower grill. Cheap square (matches the box theme
) fog lights from Walmart and some shelf support brackets from Lowes a couple of bolts and some self taping screws and your in buisness. Like I said very easy, cheap and work very well. Also if the lens gets cracked, very easy and inexpensive to replace.
Let me know if you like these, maybe I can send you a complete set (lights, Hella high power wiring harness, factory type switch, spare lenses etc...) for a little cash?
I also have a set of driving lights in clear with CATZ high power bulbs.
