Cantaloupe
So I bought an OEM fog light switch from another user here, and found out it does not fit at all. The opening on the switch is smaller the the plug housing. Does anyone have any idea how I can wire this in or make it work? If not, its for sale.
the switch looks like its an aftermarket switch, if you have a mulitmeter, you can check for continuity. flip the switch on/off while checking pins.
Pishtaco
I just soldered the appropriate wires from the white plastic plug to the wires going into the switch. Yes, they're a mismatch to the pins in the standard GB45 rocker switch that you bought. The neater way is to buy the expensive fog light switch from Toyota.
Pictures
For more photos, see this DIY thread.
