FOG LIGHT ISSUES
847 Views 39 Replies 10 Participants Last post by  statgator
i have a 2005 Xb RS2.0 with the factory fog lights, but my issue is they dont work. the bulbs are good the fuse is good (to the best of my knowledge p/t shade tree mechanic) but i resally want them to work ive only had the car 6 months and when my dad owned the car it seems like the fog lights didnt work then either. ANY HELP ON THE TOPIC would be helpful.
Thank you
1 - 20 of 40 Posts
You only have the switch or relay left
to blame
Pop the dash bezel off by pulling all the knobs off and there are some Phillips head screws behind the outside knobs
Take the screws out and then you can
Pop the bezel off and you can get to the switch.
You can disconnect the switch and jump the wires with a test light
And you should figure it from there
The relay is in a blind spot and is a pita to
Deal with
There is a very good detailed thread on the relays in the electrical section.
I added fogs and had a repo switch that didn't work and it took me a while to install the relay
But I figured it out with the help found here
See less See more
  • Like
Reactions: 1
My .02
I only just got my 06 this past January. I immediately installed fog lights that I bought off of Amazon, but had lots of good reviews. I had purchased an OEM relay. I had printed out the OEM fog light install instructions, and watched several Youtube videos on how to do it. The hardest part is supposed to be the relay, and I was able to do that with little effort. Everything seemed to fit, and plug in as it should. I tried to get the fogs to work, and they wouldnt work. I reinstalled everything again. I even swapped out the bulbs that came with the fog lights just to make sure that they werent bad. It turned out that the supplied switch was "sort of" bad.
Try the fogs this way. Make sure your headlights are turned on, and powered with the ignition key turned. Have someone stand in front of the car, or make sure you can get a good enough reflection from the front.
SLOWLY move the switch to the "on" position. As you do this, check to see if they come on at all, even momentarily, and also LISTEN to hear for the click in the relay. I was hearing the click, so I knew that the relay was good. Upon hearing the click, I was able to see that my lights were turning on momentarily, and then going off.
I had three switches sent to me from the Amazon dealer. They are all trash. I can get my fogs to stay on, but there is a sweet spot between off, and on, where the lights will stay on. It took three switches to find one, that will "stay" in this position. However, if I push the switch to the fully "on" position, the lights will go off.
If you have an OEM-TYPE switch, and not an actual OEM, they aren't made too well, in my experience, and the switch could be the culprit.
See less See more
  • Like
Reactions: 2
I feel sure by following the guidance of superbee 4406 and WhiteBread you will locate the lack of a complete circuit for the lights.
If not, here is a far-fetched consideration; possibly, but not probably, the lamps are not plugged in at the xB's front.
To my memory, the RS02 did not come standard equipped with foglamps. They were a Scion option, Part Number 08590-52820, including the lamps, relay, and switch.
Camera accessory Cameras & optics Digital camera Camera lens Font
These could be added by a dealership or by an individual. The wiring harness was already factory included and only the four items needed to be installed. After the knock-out covers were removed at the front, the wiring and plug could be reached at where they were taped out of the way.
Gesture Automotive exterior Automotive lighting Font Rectangle
Automotive lighting Automotive design Automotive exterior Font Parallel
While the lamps being left unplugged are not likely, it is possible. At least it is an easy conformation.
Regardless, good luck with the issue.
See less See more
3
  • Like
Reactions: 4
i will try all of this over the weekend, i work in a parts store during the week so no time there but over the weekend i will get on this, yes it was a factory option but when my dad bought the car he picked that option, i would like to find some yellow tinted ones being in got the solar yellow rs2 (still trying to think of a theme) thank you for all of the guidance
  • Like
Reactions: 2
Wheel Tire Cloud Vehicle Sky
Automotive parking light Vehicle Vehicle registration plate Car Grille
Rectangle Font Electric blue Symbol Fashion accessory
Light Gauge Electronic component Tachometer Font
First off try to see if the fog relay is good and go from there. Amazon or ebay OEM style switches have a lot of issues but you can also try LED back lit Toyota push switch to modernize the look of the dash. You can even order them customized like “theLexBproject“
The yellow colored light you looking for might be from an LED fixture, not halogen. Got my LEDs from Amazon
See less See more
4
  • Like
Reactions: 2
View attachment 81168 First off try to see if the fog relay is good and go from there. Amazon or ebay OEM style switches have a lot of issues but you can also try LED back lit Toyota push switch to modernize the look of the dash. You can even order them customized like “theLexBproject“
[/QUOTe}
I got a friend out in jersey his license plate says " my box " its a green RS3.0 his name is David
These are the yellows I have
I couldn't tell you where they came from
As the were given to me with a stash of parts
Automotive parking light Wheel Automotive side marker light Grille Tire
See less See more
2
  • Love
Reactions: 1
As the were given to me with a stash of parts View attachment 81223
I LIKE them they would go perfect on my solar yellow RS2.0
Those are ebay specials, Amazon might also have them these days
so far i have my dash half pulled apart (ill post pics later today) the switch is still good (to my knowledge) i put a paperclip in the pigtail and the lights still didnt turn on, i know where the fuse is but i heard there is a relay or something stashed somewhere but not sure, some help on that would be nice. thank you everyone for your help
Motor vehicle Automotive lighting Automotive exterior Font Rectangle
hope that helps you
See less See more
  • Like
Reactions: 1
hope that helps you
I LOVE YOU, lol thank you
  • Like
Reactions: 1
Not to go off topic,But anyone in the San Francisco bay area want to do a get together and compare notes,share ideas on customizing,etc..Let me know([email protected])
  • Like
Reactions: 1
Did you figure it out? I'm guessing you don't even have a relay installed. It is kind of tough to find the first time and I think guys give up.
  • Like
Reactions: 1
I had a hard time getting the relay in myself
It took me a few attempts at it
Before success. I Probably wasted about a hour into it overall at different times.
Thats your Rite of Passage 🥸
At keast you have a working pair of fogs now. Good job 👏
Even knowing exactly where it goes doesn't make it any easier, lol. Spent way too long picturing in my head and blindly left handed contorting it into it's hole. Worth it when you flip the switch and let there be light happens.
  • Like
Reactions: 1
I walked away from the job the first time and came back to it the next day and got it in under 5 minutes. Feels great when that little light turns on. Lol
  • Like
Reactions: 1
1 - 20 of 40 Posts
