Hey Guys,
So I just finished installing my Spyder Halo projector headlights...
I have two different problems.
For the fog lights, I just popped them in and they fit snug, but when I was trying to install the relay, I snapped off the white plastic part on the back of the fuse box. All the wires are still connected, and I plugged in the relay to the back and hit the switch that I also connected, and nothing happened. Possibly I got the wrong relay. The one I got is a 40amp 4pin standard relay.
Problem number 2: When I was installing the headlights, everything went smoothly until it was time to wire the Halo rings. I wanted to wire them to my parking lights so I got a volt meter to see which wire was the turn signal and which wire was the parking lights. After determining that the middle whiteish wire was the turn signal, I turned on my parking lights to see which wire was the constant volt for the halo rings. My parking lights stopped working and do not work now. The turn signals work fine, but the parking lights do nothing. The projector lights and the high beams work fine. Now I have the 2 red and 2 black wires for the halo rings just sitting loose in my engine bay connected to nothing. Is there an alternative that I can do or how can I fix my parking lights?
Thanks in advance for your help!
