ScionScotty said:yea overall i bet Joe might be highest. thatd be my guess. it will soon change though with more and more strappin on turbos. my bet: before the end of the year, there will be at least one 1nzfe in the 12s!
I seen that too, I call BS as well.rollhard said:Some guy on cardomain or something claims his xb went 13.1. i emailed him but no reply. It might be BS.
here is his link http://www.dragtimes.com/Scion-xB-Timeslip-8488.html
Vito, buy mine off me!I hate all of you... I miss my box
Well I guess that puts things into perspective!50 minutes? Dam, I wish the closest track was only 50 mins away from me. The closest track to me is Atco Raceway in Englishtown NJ...thats about a 2 1/2 hour car ride for me.
I LOVE Atco. You can get so many runs there. I used to go every Friday night. This is my last time slip from thereSimplyscion said:50 minutes? Dam, I wish the closest track was only 50 mins away from me. The closest track to me is Atco Raceway in Englishtown NJ...thats about a 2 1/2 hour car ride for me.![]()
135hp or 135whp? If its whp you should be slightly faster than me, if its hp then you are you putting down around 112-117whp which means you'd probably be in the low 15's if you can shift fast and know when to shift.preacherboy said:Vito, buy mine off me!
I think I should be able to get around killerxromances time as well with my current 135hp and stage 3 clutch, only thing that would hurt me is how fast and smooth I can shift. I just gotta go to a track and see, the closest is like 50 minutes away...so that's what's keeping me from going.
killerxromances, yeah, mine was dynoed and tuned at 135whp. But I'm working on my shifts. Sometimes it takes me a second to get from 1st to 2nd gear with this stage 3 clutch. I think that's my main weakness. The rest of the gears go smoothly. Incidentally, my old turbo did do about 10 more whp, but I prefer this setup because it is smoother, has virtually no lag, and has never conked out on me like my old setup....oh yeah, and it looks better!135hp or 135whp? If its whp you should be slightly faster than me, if its hp then you are you putting down around 112-117whp which means you'd probably be in the low 15's if you can shift fast and know when to shift.
One thing you are not taking into effect is the fact that the xb's gearing is highly aggressive. Even the autos have a slightly more aggressive gearing compared to majority of auto ratio's out there.rollhard said:Honestly, the tough part is not your shifting. Yes, the shifting will matter if you are shifting super slow but the biggest thing is to get the perfect launch. A little wheel spin can ruin your time by up to .5-1 full second.
115whp should NOT give you low 15 sec times. I know we hear a lot of guys with bolt ons running 15s but I'm sorry, I just dont believe them. The XB really is slow and not as fast as the guys want to believe. Lets take a look.
The car weighs roughly 2415lbs for the manual and a little more for the automatic right? Ok, given the average person lets say is about 170lbs. Add another 15lbs or so for gas. That gives us about 2600lbs. Most of the guys have larger wheels, stereo equipment, etc that will add even more weight and slow the car down. Another thing to think about is that our cars are not aerodynamic....AT ALL. After you reach 65+mph, its like hitting a wall of air.
So......the XB will need about 149whp to run mid to high 14s. The elise is more than 400lbs lighter and has about 100hp more than us stock,..it runs 13.5ish.
Here is a calculator that will help you get an idea. Its not 100% accurate but pretty darn close.
For example, my mr2 was somewhat gutted. That timeslip I posted above was when I dynoed 317whp. I finished with a 11.9 run. The calculator says 12.0 so its pretty good. Also that day at atco was nice and cool so my motor could have been making more power.
http://raceprecision.com/1-4 MileCalculator.htm
That website isn't very accurate at all. I mean since you used a tC in your example, i used stock tC specs for example and it showed 16.5 for the manual. Thats almost a full second off the truth. It says a stock xb manual should be 17.67 which in reality its a mid 16 second car. For the auto it says stock 18.4 and in reality its mid-high 17sec car. It says i should be running with my set up at 15.79 and i'm low 15 high 14's. There is too much that can effect times, not just power to weight. So its hard to make an accurate online time estimate.rollhard said:Honestly, the tough part is not your shifting. Yes, the shifting will matter if you are shifting super slow but the biggest thing is to get the perfect launch. A little wheel spin can ruin your time by up to .5-1 full second.
I used a TC as an example? I really dont think that the stock cars can run 17s. Its all good though, we can both agree to disagreekillerxromances said:That website isn't very accurate at all. I mean since you used a tC in your example, i used stock tC specs for example and it showed 16.5 for the manual. Thats almost a full second off the truth. It says a stock xb manual should be 17.67 which in reality its a mid 16 second car. For the auto it says stock 18.4 and in reality its mid-high 17sec car. It says i should be running with my set up at 15.79 and i'm low 15 high 14's. There is too much that can effect times, not just power to weight. So its hard to make an accurate online time estimate.![]()
