1 - 4 of 4 Posts
OK now that I have the Echo struts another minor issue has come up. I need to find a factory set of bump stops. I cut the ones I have and I cut them to short. I ran down to the LONGO deal today and I was getting a bit of rubbing. I see where its rubbing and its not in a place that I can roll. So a new set of bump stops should do the trick. Anyone have a set laying around that you took off for a set of coilovers or bags????
TIA
Shawn
A little too short is fine. They are just bump stops. Your car only hits them in extreme cases, you shouldn't be riding on them. If you lowered your car and had factory bump stops you'd still rub.
No, they are just a chunk of rubber. You hit a bump and those things will compress and you will rub anyways. The only rubbing the bump stops will cut down on is the minor stuff.
1 - 4 of 4 Posts
