1 - 9 of 9 Posts
Hi fellow clubxb-ers!
I'm having trouble diagnosing where the engine noise is coming from. I searched here and SL, and it sounded like the problem I had was the water pump.
I replaced the water pump, coolant, and belt last Saturday, but I still have the same noise! :confused:
Here's a couple of vids of how it sounds inside the cabin and outside of the car.
Sorry for the crappy video quality.
Any one know what's making that raspy noise???
That sounds very similar to how mine did when the bearings were going out in the alternator.
I second the alternator. Had the same noise on mine. I put a screwdriver on it to listen for the sound and I could feel it grinding through the handle.
Thanks wagonbldr and 06.5PW! I'll have to check that out again after work! I tried checking it this morning before work, but I didn't really feel/hear much when I put the screw driver on to the alternator, but the noise did seem to go away for a little while on my way to work, so it might be the that!
Hope you get it fixed soon, Brother Alex. BTW, glad to see you still have that classic box in your possession. ;)
Thanks Dtrain! Yeah, I hope I get it fixed soon too! The box is a little worse for the wear, but little by little I'll be fixing her up.
At least I replaced the water pump and belt before they go out as well!:D
And at least now I know how to take out the alternator! Hopefully that's where the noise is coming from.
If it is the alternator, I'm thinking about getting this one:
Scion XB High Output Alternators
160 amp output and its a direct fit...oh yeah!
I think it's the A/C Compressor :crying:
I placed a crowbar to my ear and then to the alternator, water pump, and A/C compressor. It sounds a lot like its the A/C compressor.
I was really hoping it was the alternator. I can replace the alternator on my own for less $$$, but the A/C compressor is another story.
I'm thinking of taking it to a shop, but don't know if I should take it to a mechanic or A/C specialist.
Any advice?
1 - 9 of 9 Posts
