1 - 12 of 12 Posts
Most I know that are running one, are running the Weapon*R dampner.
where is a good place to buy one for a reasonable price???.....and where does it install on the engine????does it bult up, or do i have to drill anything??? some pics would be sweet. im kinna a visual guy. i bet if i saw a pic of one installed i would be ok.
It mounts from the passenger side strut tower to the upper engine mount near the alternator.
They keep the motor from moving and giving you wheel hop. Makes for more vibrations through the car. More power to the pavement.
polarproject said:
is that the only downside???......the vibration in the car?.....
Pretty much, kinda like urethane motor mounts. Transfers the vibrations thru the car instead of the mounts. So i've heard, I don't have one.
Yes, the only downside is you will feel the engine better through the car.
They help by reducing the amount the engine rocks around on the engine mounts. Like stated above, it reduces wheel hop and helps plant the power on the pavement.
I put the motor mount polyeurethane inserts on my CR-X. It did make a difference. The car felt more reponsive due to the power being put towards the drive wheels versus moving the engine in the engine bay. I did also feel more of the engine through the steering wheel.
1 - 12 of 12 Posts
