1 - 15 of 15 Posts
can anyone shed some light on endlink bushings?
what does it do?
is it worth it?
any noticeable difference?
how hard is this to install?
what sizing do you have to use for the xb?
is this where babies come out?
HORNBLASTER
they go on the front sway bar there the bushings that go inbetween the swaybar bolts at each end theres usually 4 to each side. there not hard to change out / try to find some urathane ones it will stiffin up the front takes all the slack out of the front sway bar / i know auto zone had them not sure if they still do tho
HORNBLASTER
nope u can do one side at a time unbolt the bolt that has the bushings on it put the new ones on bolt it back together .
Discussion Starter #8
Spiderbox said:
so i will need 4 sets of 4?
whats the difference between the hourglass shaped one and flat ones?
is there a specific size I need to get?
wait a second whats the difference between this http://store.summitracing.com/partdetail.asp?autofilter=1&part=ENS-9-8122R&N=700+0&autoview=sku
and this ?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ENS-9-8126R&N=700+115&autoview=sku
Just buy this set.
There is no difference in the bushings in either picture.
^^^ Them better be the right ones, I just ordered them! ;)
I was needing this info a couple months ago, thanks!
RS4 #303
look closer
one is just bushings(use old hardware)
one is bushings, nuts, and bolts:D
check that measurments are for xb
bush o.d.
bush i.d.
bush length
I'm too lazy and I don't have time. They should be sending mine out today.
1 - 15 of 15 Posts
