Skeeter said:You just have to work on it, it will all come off, roll the windows down and pull the rubber gasket out of the door frame and from the outisde edge of the door so you can get to the tape that is rolled around the inside and outside of the door, as far as the tape behind the molding, once you get down to that part you can either pull the molding back slightly and pull the tape out some heat may be needed or help or pull the molding back and cut the tape leaving a bery small portion behind the molding, once you get is started try using some goo gone once you ahve the tape removed to clean up the adhesive, it may even help loose the adhisive up to get the tape off. I bave removed it on all 3 of my xB's
I did use the hair dryer but then i just gave up with the hair dryer and pulled it off in 104 degree heat and it came right off.Liesjemt said:I think Caden mentioned using a hair dryer to heat it up when she did hers.
Good Luck!
Are you talking about the middle post in the back doors?azynboi03 said:how did you guys take out the rear the in in the middle of the windows that a pain i nthe ass im having a hard time on that one thanks
yea thats what i was talking about thanks also does anyone no how to take out the molding at the bottom of the windows besides the cut the blackj tape i want to make it clean thanksHeGaveMeGreenEnvy said:Are you talking about the middle post in the back doors?
If so that is not taped, Skeeter took those and painted them for me.
pics of the tape off?azynboi03 said:ok koo thanks
that looks pretty good! i like the look alot!Sir said:^^I took just my front doors off, I like the way that looks better....almost makes it look two door at the first glance.
