1 - 20 of 31 Posts
does anyone have a dyi door lock led guide? i bought some for like $35 but cant seem to find how to install them ! Any and all help appreciated!
they are real easy to put on and very bright. The hardest part is running power wire if you are running them off of a switch or the head lights. I had already ran a power wire to a switch in the doors for the LED's I have in the pocket,door handles,and around the speakers so I just put on an inline tap tee and put the ground on a bolt that holds the window in place straight down from the locks.
They make the window glow real nice right there.
Is their a easy way to run the power wire from the door to the in side of the car. Need to get the power wire to a switch up front. I tried running it through the lil rubber with all the other wires but had no luck. Got frustrated and stopped.
Thes are just an idea of how I did it. attempt at own risk. If you have questions feel free to ask. I might be able to explain better than I do hear.
The easy way to get the wire through there is, Back door first
1:peal the vapor barrier back or take it off(your preference)
2:reach in and grab the rubber bootand slide it down the wires to the inside of the door to get it some what straight.
3:take a long skinny flat head screw driver and fold the wire over the tip.
4:take some electical or masking tape and do one wrap to hold the wire in the screw driver.
5: slide it in the boot from the bottom of the boot and position the little hole at the top of the boot so the screw drive can come through.
6: grabthe wire and pull it of the driver.
7: now try to put the boot back in possition(it is a pain but after you do it once it gets easier)
Front doors: these are much harder
1:peal back or remove vapor barrier
2:I took out the front speakers by drilling out the rivets but you could just reach in from the opening further down the door.
3:there is a white clip holding all of the wires to the inside of the door just take a flat head driver and push it in from the door jam
4:slide the boot down the wires into the door(these are harder thats why you do the rear doors first to hone your skills)
5:fold wire over tip of screw driver and wrap with tape.
6 work the screw driver through the boot and grab wire
7: replace boot.
Sorry for the crappy write up but I am in a hurry Iwake up for work in 5.5 hours.
This sounds kind of hard but be patient and dont force anything.
After you get the power wire run to a switch you can put lighting just about any where on/in your door.
When I figure out how to post pics on here I will show all of my lighting and maybe do a DIY on some lighting
cool thanks for the info I'll try it this way with a screw driver I tried a cloth hanger but I couldn't get it a ll the way through the rubber. To post pics just click on manage attachments at the bottom in the additional options section when you post a reply
I got home from work and I hooked up my Led door lights, 2 of the 4 for lights in the grab handle 2 on back order from oznium.com. thanks again for the tips but I used the bottom straight part of a coat hanger to run the wires with tape. I'll post pic later so don't call the pic po po.
Sorry to post this after you finished...I ran CAT 5 wire through both of my door sets, front and rear. This way I only have to run the wire one time and I have four pairs of wires to each door. This allows me to send power through the doors for different items. It was a beyotch to get it through, but I only have to do it once.
INGENIOUS! CAT5! i would have never thought of it!:eek:
Thanks on the picture tip.
Got Bags?
i don't want to have to order from superfa.
It cost too much anywhere else i can get these?
nope not that I know of if you get them off of ebay then it's still comeing from them. But that is about the cheapest you will find them.
Got Bags?
HELPPPPPP
HOW DO YOU TAP THE WIRE IN????
i recieved my lights today but i can't figure out how to tap the wire in.....
1 - 20 of 31 Posts
