1 - 12 of 12 Posts
I have checked the switch on the light, and when it is set to "Door" the light still will not come on when the door is opened.
I had tried to wire in some led's under the dash, but took it out after I had this problem. I am really at a loss because it still comes on when in the "On" position, so any help would be appreciated.
Just a time saving question.... Did u check the fuse. I hate wen I'm looking for a problem ad it ends up to be simple like that.
@HFDane on Instagram
I actually have the opposite as you. If I turn the dome light on, nothing happens...but if I have it set to door and open the door the dome light pops on. This happened after installing LED strips under the doors that I wired to the dome light.
Discussion Starter #8
gohangt, I looked for the fuse, but wasn't sure which one it was. I also tried disconnecting the battery for a few hours, but that didn't help either
1 - 12 of 12 Posts
