OG Member
Ok so we all member the wheel swap at Scion Nats right?
Here are the new things on the box for Az.
1st DIY post. Didn't think about it until I was almost done. If you have any questions we are here to help.
If you get hurt or do something stupid it's your fault. :D
25mm Project Kics spacers
Jack the car up and remove the wheel.
Install spacer. If you have the lugs that come with it GREAT!
If not, I used the smaller lugs to hold the spacer to the break drum.
They worked out great.
Now put the wheel back on and lower the car.
Before:
After:
OG Member
Discussion Starter #6
Re: Project Kics 25mm
Little by little.
Still have to do some things before we leave at 5am for Az.
Thanks guys
