1 - 4 of 4 Posts
South Bound
In case you are unable to follow my video I made you can follow these instructions.
First turn your car keys to the ACC
Next let the radio come on then turn it back off with out taking the keys out
Then with everything off hold down the "Mute" button and turn the keys back to ACC
Then the line below the Station will be flashing
Then after it starts flashing press and hold the "1" button, and you are now in the edit mode and can begin to edit it
After you enter the editing mode....
The 3 is used to shuffle through options backwards
The 4 is used to shuffle through options forward
The 5 is used to delete the previous entry
The 6 is used to advance to the next letter
The 6 when held down for 6 seconds also saves the entry
While editing the dinging noise gets annoying so turn the keys to off BUT DO NOT TAKE OUT
Pishtaco
Thanks. I'll have to try this. I'm not expecting it to work with all the different radios offered for sale in the xBs, but who knows how Toyota wrote the specifications?
Pishtaco
Probably not going to work with the stock Alpine DVD unit in my RS 3.0, though.
1 - 4 of 4 Posts
