1 - 2 of 2 Posts
To remove use a small screwdriver and pop loose the clip that holds in the visor; there are two, one on each end but it is disguised as a single clip. Just use the screwdriver in that center portion and pry to the outer edges.
You don't have to remove the clip, just pop it down enough to release the clips and pull the visor down. Push the clip back into place so you don't lose the $3 clips.
To reinstall just push it back into place starting with more pressure on the front clip then the rear clip.
To remove the visor support just twist it and pull down
Then to remove the housing squeeze together the two plastic clips inside and pull down:
To reinstall just push the housing back in and push the hook assembly in perfectly straight( Do NOT twist it back in like when you removed it!)
1 - 2 of 2 Posts
