1 - 3 of 3 Posts
I attempted to install rear lowering spring on my 09, The rear suspension was completely off the ground, when I installed the springs bolted the factory shocks there was still a lot of room from the top of the spring to the underneat of the perch. Is this normal untill you put the car back on the ground and have load on the supensio? I dont want the springs to pop out while going at an angle over bumps or up a drive way.:(
Lots o leather and copper
Yep, perfectly normal. You would have to get the car air born to get them to pop out.
Thanks for the info. I wasn't sure if it was right. I've done plenty of trucks bit this is my first with rear coil springs.
1 - 3 of 3 Posts
