1 - 1 of 1 Posts
If anyone is interested, I tested the amperage draw of the Bazooka tube that's optional on our Scions. I have a beefy 12 volt power supply that measures current draw and the like. I have an Identical Bazooka EL8A tube that hooks directly up to the Scion subwoofer cable. I powered it on my test bench and tested the tube with different frequencies. I tested with frequencies between 20 and 100 hz (Bass Mechanik CD) and measured 7.5 amps of maxium current draw at 13.8 volts. So, if anyone is concerned about how much the Bazooka draws off of the stock Scion electrical system, you now have a general idea.
Troy
1 - 1 of 1 Posts
