1 - 20 of 22 Posts
Blah.. :D
so i just installed a new cai. at first it was running well.. made my exhaust louder.. i left it on for a bit then turned it on then off.. i closed the hood of the car. turned on the car again and it stayed on but when i stepped on the gas, it wouldnt accelerate as much.. it sounds like if its gonna choke but it stays on. also.. the vsc/traction/check engine lights lit up... i already checked for leaks.. cleaned the maf sensor with a qtip.. reset the ecu and nothing... any clues??
asap please.. :(
Which CAI did you get?
Not a cheapy knock off off e-bay I hope.:eek:
Did you double check all connections?
Did you re-set the ECU?
Did you check to see what may have been knocked loose? connections ? in and around the intake areas?
Is the vacuume/electrical switch in the upright position ( same direction as stock)?
Blah.. :D
i got the bomz one since i heard good stuff about it.. right now i hooked up the stock air box and still doing the same thing.. :S
just re-read your original post.
get your self a MAF sensor, you touched it with a q-tip. that is a big no-no.
you only use something like "QD Electronic Cleaner", turner cleaner from Radio Shack,Fry's, that sort of place. you lightley flush it and then blow it dry with your breath.
you touch it and break the wires, your screwed.:(
this is just my best guess if it is still doing it after replacing your stock air box.
Blah.. :D
thats the thing.. i just cleaned the tip if the lil wires of where a "water drop" shaped forms at.. it had a lil bit of dirt so i took it off with a dry 1tip.. none of the wires broke off.. i accelerated the car pressing down on the gas and the rpm needle wont pass the 4 on the rpm.. more like 3.5 .. after that it just starts stalling.. i took it out for a test drive and when i accelerate, itll stall like if its pulling back at 3.5rpm...
your in "limp mode", she will run that way until she sees a dealer, or you fix the problem. it doesn't take much to mess up that little sensor.
try taking it out, disconnect your battery first, clean it with tuner cleaner by gently spraying it lightly, apply connector grease ( bulb grease) and reconnect the MAF. re-connect the battery , it should have been disconnected for 15 min now,and see if that helps.
if this doesn't fix it, take it to the dealer w/stock air box on it and have them fix her up, may be your only hope.
it will need the codes cleared ( disconnecting the battery might do it)
but yeah, she is in limp mode now.
Yep, try the cleaner. ELECTRONIC CLEANER. QTIPS are for your ears.
If it is a bad sensor, who cares, put the stock stuff on, take it to a dealer and get it repaired.
Also, some of the oil based filters have TOOOOOOO much oil on them. I'm guessing you revved it a few times to hear the new sound. It is possible to sucked up some oils onto the sensor.
Again, ELECTRONIC CLEANER. Clean the sensor. Clean the filter as well to take off the excessive oil. Then re-oil lightly. You can usually purchase a K&N cleaning kit at most places that sell K&N Filters.
OR
Replace the filter with a AEM dry filter. Zero cost to maintain.
Blah.. :D
OR
Replace the filter with a AEM dry filter. Zero cost to maintain.[/QUOTE
yeps.. it was maf sensor... tommorrow ill go pick one up at autozone.. id go to the dealer but im the second holder on the pink so the warranty doesnt cover me at all.. good thing the sensor is only like 100+i have to return my old one to get it at that price otherwise itll be like 160.. :/ yikes... ballin!
You just cant win, can you. Good luck.
Blah.. :D
Discussion Starter · #11 · (Edited)
Fcuk!!!!!!!!!!!!!!!!!!! I finally got my cai to work... here are some pics of b4 and after.. im running the Bomz Racing CAI... i test drove it and i revved it at a red light and damm... let me tell you guys, my exhaust got louder... and i feel a little more pull on take off's... good looking out guys.. thanks!!!!
[/URL]
Before:
After:
Now.. just have to install my new halos and some side graphics... ill keep u guys posted on those pics too.. :D
Whoo hoo. That is awesome. You finally got one to work.
Now I can sleep at night and not think of why that blasted thing wont work.
Blah.. :D
Discussion Starter · #13 ·
lol... it was the maf sensor that was fukdec up... i got another one at autozone for 103bucks and installed it and vualah!!! bamm.... sucks air like a mofo...
Blah.. :D
Discussion Starter · #15 ·
yeh.. u should see me riding down the 5 fwy.. the throttle response kicks ass.. plus i like the sound it makes when i turn off the car... :D
Blah.. :D
Discussion Starter · #17 ·
yeah. that whirpool of air sound when you turn it off is awesome. glad it finally worked uglyfrog.
oh fo sho.. now i can race.. lol ... jajajajaajajaja.. ajajajaja.. that was a good one..
1 - 20 of 22 Posts
