As the thread title states, what's the best setup? If money was no object.
I want to go as low as possible, but don't want any sagging issues I hear about. HKS, Cusco and Blitz do not offer specs on ride height adjustment. Does anyone know the true specs? Or if you have pics with your ride on them? Tein's do not adjust low enough for my preference. I would like lower than a 2.8" drop.
Also any info on K Sport would be appreciated. Anyone had any experience with these?
If money was no object, I'd go Zeal - have verything made to your specs.
Out of the 3 you posted, I'd go with Cusco, then HKS, then Blitz (all range from $1200-1500):
-Cusco is the most complete system that can go down just about 3.8" all around and still ride great (I'm at 3.25" and it rides better than sstock - sorry no pics).
-HKS goes at least 4" in front but supposedly has too low a spring rate for low offset wheels.
-Blitz goes slightly lower than Tein Basics, but has the best handling ride (see my profile for Blitz at almost Max drop).
Progress is supposed to be really great if your on a budget.
I have a set of JIC Magic Coilovers that will drop 4+". Currently, my car is dropped at 2.5 all around (I can't drop lower yet due to my rim/tire set up). But it can still drop a lot more. My rears at almost to the top still and have plenty more to go down. The fronts are over half way up, with also plenty more drop to go.
All the different Cuscos can get confusing. Check the Cusco Japan website for more info.
I have Cusco Vacanza Zero Wagon with Super Low springs. The Zero Wagons lower with the shock body not just the spring. They come with camber adjustable upper mounts. Shocks and struts are non-adjustable.
The V-Wagons (which Aireck have I think) adjust at the springs only, but they go a little lower.
Lately, I've been seeing Cusco Zero1s for xBs with almost exact same specs. They might have adjustable shocks too...I'm not sure.
todd i have the D2, ask jason on the drop height. if i didnt have the tire set up i have now, i can drop another 3in.
im gonna see jason at the shop friday to put on the MKIII. i may drop more then since i'll have nice room to tuck.
dont puss out Eric! lol. Its not that bad. Im currently rocking like 2 and 3/4" of clearance on it because of the Ns and their needed clearance. Youll see. Its not that bad. An inch of clearance is more than you need.
You ride is controlled much more by your spring rate than by your dampening. And with the very high race oriented spring rates on the K Sports the finest tuned dampening in the world isn't going to help a thing. A set of K Sports with the right spring rate (and possibly modified dampening settings) could ride smooth as silk on the street.
If all you want is two inches and good handling, forget coil overs. Get yourself a set of Tanabe DF210s and swap out the rear shocks for Monroes. You are looking at just over $200 instead of a minimum of $600+.
i'm running on h techs and monroes and it rides like ass
You have insufficient privileges to reply here.
Related Threads
Scion xB Forum
1.1M posts
33.6K members
Since 2005
A forum community dedicated to Scion xB owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
