1 - 15 of 15 Posts
kazyboi
im getting my raceland coilovers this week, what is the ideal drop (like Inches) avoiding regular bump and curve scratching, but still has that lowered look? :) thanks guys!
kazyboi
Discussion Starter #5
Height Adjustment
sorry guys cant post on the right place to post this. but i have a quick question. I just car lowered with coilovers. do you think the tire pressure can also can make a big diffence on the car's height? cause i noticed that my left side is lower than my right side? thanks guys.
Premium Member
Re: Height Adjustment
First always run the correct tire pressure in all four tires. Second your car was obviously set up off the car to have the same settings on each front strut. The driver's side of the car is a lot heavier than the passenger side because of the layout of the car. So you either have to raise the driver's side a little or lower the passenger side a little to make it even. Always check ride height with the car on level ground to make sure it is even.
I have the same issue and it seems to be a common problem among xB's for the driver's right side to be slightly higher than the left especially the rear passenger side wheel well.
NorCal - East Bay Area
That's because a lot of people don't know what their doing when slapping coils on their car. You need to measure. Measure again. Measure with weight approximate to yours in the driver seat. Then lower/raise to adjust to meet your measurements to make it level.
True, but I had S-Tech's with waydoo sportivos before and it was the same thing. Car handles and drives perfect, its more of a visual deal than anything and its like 1/4" off. With the S-techs it was like 1/2" off.
kazyboi
Discussion Starter #10
quick question regarding window visors
so i got some window visor! just put it but my rear window cannot be close all the way up? is it normal? sorry noob
Re: quick question regarding window visors
Sounds like you have the in-channel window visors. Are they made by Wade?
kazyboi
Discussion Starter #14
no sir they from cheap ass auto ventshade what shoul di do?
---------- Post added 03-02-2012 at 06:04 PM ----------
auto ventshade i got from ebay
1 - 15 of 15 Posts
