Installed the coilovers yesterday and was driving it on the city for couple miles with ko issues until I drove it on the freeway, when I exit I hear these clicking noises on bumps and when I'm accelerating from full stop. Pls help
Dyke in a Box
Does it only happen at low speeds? Is it affected by turning at all?
Dyke in a Box
From the research I've done it might be a wheel bearing or CV joint causing the clicking. If you put the car in the air is there any give in the wheel? Like can you jiggle it up/down? If so, that might be wheel bearing. If there's grease everywhere (you'll know it when you see it, it's nasty crap) then the CV joint's boot has ripped and leaked. Just two possibilities.
---------- Post added 04-11-2015 at 07:33 PM ----------
Er, by "wheel" I mean the wheel itself, not the steering wheel. I reread my post and realized it sounded a little ambiguous.
Discussion Starter #5
It's not the wheel bearing, my car was completely fine until the coilovers was installed
Premium Member
double check the top hat center nut, the three mounting points, and your allen bolts holding the camber location on the camber plate.
