1 - 3 of 3 Posts
looking for a hand holding guide on the headlamp clearing process.
(reflector removal)
per heat oven to 350 degrees let headlight sit inside for 5 min pull out head light pull them apart then take out amber....... if you dont want to use the oven use a heat gun or a blow dryer and a flat head screw driver and slowly pull it apart...... it will be a mess to do that tho
stick a screw driver in the turn signal hole, break the hell outta the little reflector and use a pick or what have you to get the rest of the crap out.
rule 1: be carefull
rule 2: this is NOT foolproof
rule 3: you might not get all the reflector out and end up doing the bake and take method.
this is also known as the 'break and pick' method.
1 - 3 of 3 Posts
