The hatch itself is not that hard to install. It’s prepping your CF Hatch. What I mean by that is, you need to drill (Dremel) out the areas where the latch, electrical loom, defroster plug, and few areas where your hardware for your latch mechanism may go. But it depends on the maker of the CF hatch, they may have it pre-drilled.
I have the "bB style" CF Hatch, which means the handle/latch, is different from our USDM handle/latch. I purchased the bB handle and the mechanism from a vendor stateside. They did have it shipped from the motherland. Surprisingly the cost was very affordable; some people told me that it would cost several hundred dollars for it, but not from these guys. Great price!
I had a glass installer come to my house to install a PPG for around $150.00?, with defroster, and using a brand new seal/rubber trim. He was done in 20min.
I had the hatch laying flat and had the silicone/sealant cured for a whole day. No leak at all.
The hardest part for me was to remove the OEM hatch dampener. That was TIGHT.
Also with the bB hatch, you need to fabricate a lic. Plate holder, unless you get a bB style bumper. It just depends on your style. I fabricated the old style custom rod plate look. I installed a LED lights for the plate also. They are called "Lightning Bolts" from MOONEYES in Santa fe springs. 15-20 dollars a pair.
I only know of 3 of these CF "bB Style" hatch in existence at this time. There maybe few more out there, but I haven’t seen it except on yellow_sub (James), jaydmxb (Paul), and yours truly.
If you want to get a USDM CF Hatch, check with
NEXT LEVEL MOTORING and talk with Ryan. They have great prices.
If you purchase the hatch from *NEXT LEVEL MOTORING, I’ll help you install it at my residence by Appointment Only.
(*NEXT LEVEL MOTORING is not responsible for the install.)
I also know of a glass installer that will come to your house to install the glass for the price of the glass, and to install. (Prices are subject to change)
Hope this helps.
