1 - 8 of 8 Posts
hope this helps
Synthesis
Each carbon filament is made out of long, thin sheets of carbon similar to graphite. A common method of making carbon filaments is the oxidation and thermal pyrolysis of polyacrylonitrile (PAN), a polymer used in the creation of many synthetic materials. Like all polymers, polyacrylonitrile molecules are long chains, which are aligned in the process of drawing fibres. When heated in the correct fashion, these chains bond side-to-side, forming narrow graphene sheets which eventually merge to form a single, jelly roll-shaped filament. The result is usually 93-95% carbon. Lower-quality fiber can be manufactured using pitch or rayon as the precursor instead of PAN. The carbon can become further enhanced, as high modulus, or high strength carbon, by heat treatment processes. Carbon heated in the range of 1500-2000°C (carburizing) exhibits the highest tensile strength (820,000 Psi or 5,650 N/mm²), while carbon fiber heated from 2500-3000°C (graphitizing) exhibits a higher modulus of elasticity (77,000,000 Psi or 531 kN/mm²).
[edit]
Textile
These filaments are stranded into a thread. Carbon fiber thread is rated by the number of filaments per thread, in thousands. For example, 3K (3,000 filament) carbon fiber is 3 times as strong as 1K carbon fiber, but is also 3 times as heavy. This thread can then be used to weave a carbon fiber cloth. The appearance of this cloth generally depends on the size of thread and the weave chosen. Carbon fiber is naturally a glossy black but recently colored carbon fiber has become available.
[edit]
Uses
Carbon fiber is most notably used to reinforce composite materials, particularly the class of materials known as graphite reinforced plastic. This class of materials is used in high-performance vehicles, sporting equipment, and other demanding mechanical applications; a more thorough discussion of these uses, including composite lay-up techniques, can be found in the carbon fiber composite article.
Non-polymer materials can also be used as the matrix for carbon fibres. Due to the formation of metal carbides (i.e., water-soluble AlC) and corrosion considerations, carbon has seen limited success in metal matrix composite applications. Reinforced carbon-carbon (RCC) consists of carbon fibre-reinforced graphite, and is used structurally in high-temperature applications, such as the nose cone and leading edges of the space shuttle.
The fibre also finds use in filtration of high-temperature gases, as an electrode with high surface area and impeccable corrosion resistance, and as an anti-static component in high-performance clothing.
Some string instruments, such as violins and cellos, use carbon fibre reinforced composite bows. This is an alternative to the more common wooden bows.
Many high end frames for road bikes and mountain bikes are made of carbon fiber reinforced composite. Also, many road bikes made of aluminum have carbon fiber reinforced composite seat posts, handlebars and forks for reduced weight.
[edit]
Future Directions
Carbon nanotubes are currently being investigated as possible improvements on the traditional carbon fiber material. While the nanotechnology field isn't advanced enough to create long-enough fibers made entirely of carbon nanotubes, research has shown that even as little as 5% (by weight) carbon nanotube constituents within the carbon fibers will dramatically improve properties. Andrews et. al. reported [1] that tensile strength increased by 90%, modulus increased by 150%, and electrical conductivity increased by 340%. This was in a pitch composite fiber with 5% (by weight) loading of purified single walled nanotubes (as compared to the corresponding values in unmodified isotropic pitch fibers). Further research is still needed to resolve issues such as nanotube dispersion and alignment, as well as interfacial bonding; however, this approach holds great promise for improving both the mechanical and electrical properties of carbon fiber composites.
thank you all for your time and answers
so i just cant make it in my garage lolololo
nah, really can't, but if you ever learn how to work with it let me know!
1 - 8 of 8 Posts
