First of all, hello! This is my first post and the reason for which I have created this account. I am hoping somebody lurking on this site can help me out.
A couple months ago I bought a 2005 Scion xB that needed a clutch replacement. I was able to drive it home and replace the clutch and flywheel in my garage. Upon reassembly, however, I ran into a huge issue. While removing the transmission, I made the mistake of undoing the four bolts holding the gear selector shaft assembly (that is what I am calling it, but I can't even find a part name or number even after calling dealerships) into the top of the transmission. I pulled it out an inch or two before thinking "hey, this seems like something I DON'T want or need to be messing with" and sliding it back in. I then did what I ought to have done in the first place, and simply disconnected the shifter cables from the assembly, and carried on with the repair.
Upon reassembly, I realized that the "arm" that connects the shifter cables to the selector shaft was pointing towards the driver side of the vehicle. It is supposed to be facing downward, so it was rotated 90 degrees from where it should have been. It still seemed to move in and out and side to side properly, so I assumed it had just gotten rotated when I took it partially out by mistake earlier. I undid the four bolts and tried to pull it out just a couple inches in order to rotate, but it would not rotate to the proper position. After trying this many times, I decided to just take it all the way out, thinking I might have an easier time aligning the parts. It slid out with no resistance.
Since I left the transmission in neutral, I aligned all of the parts on the selector shaft in the middle and tried to slide it into place. After a little wiggling, it slid into place! However, I then realized the "arm" was pointing towards the passenger side of the vehicle, so still 90 degrees from where it should have been and a whole 180 degrees from where it was when I started! I laughed and tried again to remove the shaft, but despite how easy it went in... it wouldn't come out! Not only that, but it wouldn't move in and out or side to side at all.
This is where I am today. I am afraid that something on the shaft rotated inside the transmission and is now preventing my from removing it. I have tried wiggling and wiggling, and even used quite a lot of force (not a tremendous amount, though, as I am afraid of breaking it) and it still won't come out. It will come out about an inch or two, and then will wiggle and move freely, but will not come all the way out, and if I push it back in, it will slide in easy but then will not wiggle or move until pulled out again.
Please help me! I don't have the money to get a new transmission and I am not mechanically inclined enough to take apart a transmission. Replacing the clutch was the most involved job I have ever attempted.
Thanks in advance~
Thanks in advance~
