hello,
I've got a couple of questions about these avs vent visors I just picked up, while attempting to install I've found that the little black clip on the window doesn't line up with the groove in the visor I was wondering 1 what the little bugger is called and two can it be moved or is there something I'm missing?
any and all help would be greatly appreciated thanks!:)
RS4 #303
Put the visor up to the window and mark where it needs to be moved. Pull down the rubber seal to expose it. They are on with double sided tape, pull it loose and relocate.
RS4 #303
Its actually attached to the underside of window frame beneath the rubber seal. It goes across the whole track under there
---------- Post added 06-05-2015 at 08:58 PM ----------
This is the part # for the clip you can Google image it for a look see 62367-60030 :) you should notice the other side on the inside of window
Mine don't line up either with my weathertech visors. Doesn't bother me enough to try and move them. I'm sure I would end up breaking something in the process.
