1 - 8 of 8 Posts
Folks,
I am nearing the time to install my amplifier. Can any of you tell me where in the engine bay and at what location on the fire wall you ran your power cable from the battery to the interior.
I'd lrather hear from someone who's done it so I don't mess up my Box. Thank you in advance!
Troy
After you ran the wire in through that harness, was it fairly easy to find it inside the cabin? Was it fairly easy to force through that grommet?
06.5 TCM
This is Gauge 4 wire. Not very easy but very doable. Pull the stock grummet out of the firewall, cut off one of the tips, then you will need to make a small cut on the inside of the grummet through which wire will go inside the passenger comp. Then feed a rope through the grommet from the engine compartment inside the cabin. It will drop from behind the heater/AC housing. Tie your amp wire to it and pull it out back to engine comp. I used talk powder rather than WD40 to make everything easier.
Discussion Starter #5
Thanks PCH! Exactly what I was looking for. I think I will go the same route you did. I'll only be using 8 AWG so, I don't think I'll have any probs.
You can also use the one on the driverside, that will come out above the pedals. I don't have a pic, but i just pushed it through, and it went easy.
I ran a 1 gauge wire from the battery out the fender well, I removed the fender inner liner, where there is a gromit way down near the bottom of the car, I poped that out ran the wire through it, went in the car poped the toe kick panel off, removed the foam and found my gauge wire, then ran it along the door sillwith all the other wiring to the back of the car. I saw on another forum this guys was drillin holes and crap, no need!!!!
Discussion Starter #8
Thanks everyone for your replies. I actually used PCH's method. It worked perfectly as I'm sure the other methods mentioned here would as well. Ahh... the benefits of this forum. Outstanding!!!
1 - 8 of 8 Posts
