1 - 4 of 4 Posts
So I have the extended warranty from Scion/Toyata dealer ...I wanted to started modding my box since I have it for a month in stock. But since $ is limited, i have to do one thing at a time. For instance if I add a K&N air intake coolin system typhoon
Do it void the warranty if I decided to put it on myself? The one they are sellin at the dealer is freakin expensive!
I have the Typhoon, have had no problem with dealer doing warrenty work.
Just make sure you clean it inside and out with water and dish soap. The tube, not the filter. Make sure it is dry, and re-set your ECU in the process, it will happen naturally when you remove the battery.
I even took it in for work with my DC Sports header with no problem.
Both are CARB Legal, which helps with any dealer problems.
what ya saying , if i installed the typhoon, the warranty wont void even i added an aftermarket intake?
I really need to put this somewhere that I can access it easily. Here's my standard spiel on voiding the warranty:
"If you attach an aftermarket part to the car, ANY aftermarket part, and it causes the car to fail in some way, can you really expect the manufacturer to pay for that?"
Apply that to any warranty question you have and you'll be fine.
-Alex
1 - 4 of 4 Posts
