I did a full vacuum and refill of r134a last year, AC was working great but this summer I noticed it was blowing little warm.
When idling, the air is around 75 when ambient is 85 but when I rev above 2500, AC blows 60 degrees.
Touching the low or high pressure hoses, it’s not cold at all, I recall it was cold last year. Is it normal?
You could be having issues with the compressor. How old is it? Was it ever replaced?
I'm figuring when you charge it and it runs out quickly it's the compressor- AC compressors and units do leak r134 but it's only supposed to be a tiny bit- my guess is the compressor. That's my 02 cents- others should chime in.
thanks, if it is a compressor- is that the only thing that needs to be changed? condenser shouldn't need a change right?
Any recc of what compressor to replace with, OEM Denso or another equivalent from Rockauto
I would go OEM if that's too much Denso is top notch too- I don't think the condenser needs changing- see how much it is anyway-
