Aloha~ My first post here. Thank you to everyone who shares what and how they do to their XB!
AC compressor locked up and ripped/threw the belt. Not in a place ($$) where I can replace the compressor (and all the other related parts…..which sounds like, basically every part, just to eliminate the possibility of contamination of a new system…) and wondering if anyone can share a part number for a belt which bypasses the AC and still catches the alternator and water-pump.
I saw somewhere someone mentioned a 360K4 belt from Autozone and wonder if that number translates to a 360 mm length, 4 groove belt? Anyone have a NAPA or other part number No Autozone store here, though I suppose if that is correct number, I might be able to find one online.
Thanks for any advice/assistance….
Not sure, lemme check.... this gates site lets you search by inches or mm to find belts and gives part numbers tho.......
OK, the part number from autozone is their valuecraft 4 rib belt that is 36.7 inches in length. If that is the belt someone used to bypass the AC then you can find whatever brand 4 rib belt part number using that length.....
Gates Micro-V K040360......36.75"
Goodyear.........
I haven't done a bypass belt for the xB but have played around with shorter belts on my Mazda that has a smaller underdrive crank pulley. Let us know how this turns out and what length belt works.
