Hello. I just wanted to add to this A/C discussion. I had my compressor and condenser replaced back in February. Once those were replaced, it blew ice cold again for about five months. At the end of June I noticed it stopped cooling. Brought it back to the mechanic who replaced the parts. They found the leak in the A/C valve where you charge up the system with freon. They fixed it free of charge and I went on my way with cold A/C again. Brought it back a second time and they noticed the freon was low and charged it up again as they saw no other leaks. I went on my way again with nice cold air. Had to go back a third time and they took apart the dash and ended up having to replace the evaporator as it had started to leak now. That was completed this past Tuesday and since then, my A/C has not been as cold as it should be. The mechanic told me that he read the temp coming out of the vents at 40 degrees. Well, I can assure him, it's not blowing anywhere near that cold. Since having the evaporator replaced, it's not blowing as cold as it should be. The car just never seems to get to that cold point where you can turn the blower down and run it on low. Something just isn't right. Anyway, I am taking it back to the shop tomorrow, but I wanted to bend your ears and see if anyone else out there has had or is having that same issue and if you were able to fix it, what was it or what do you think it could be now? Thanks guys! I would have posted a new thread, but I am still new here.
-Chris
