I recently installed aftermarket fog lights on the xB and everything seemed well afterwards. Had to splice into the factory harness but that was easier said than done at first. Once I figured it out, lights worked as intended.
Now here’s the issue:
Some of the HVAC indicating bulbs don’t light up now, so it’s not easy to see where it is set at night. Also the PRNDL light doesn’t light up either. I did meter out that socket and its shorted out. Also, bulb works fine so I’m not sure where to start.
No voltage either, should’ve mentioned I checked that before checking continuity. All fuses in front are good too.
Any pointers or tips are appreciated. I’m at a loss and the gf hates that she can’t see the lights anymore, thanks!
