1 - 3 of 3 Posts
I have to replace a failed Radiator fan motor... Since I have 185K on this car I probably will replace the shroud and both fans.
It looks like there's enough room around the AC High Pressure pipe that I should be able to lift the condenser clear of the shroud and support it while I do the work. Has anyone been able to do this without damaging this very small aluminum pipe? Thanks!
Lots o leather and copper
Yeah, it comes right out with no problem. I replaced my radiator with a Mishimoto one and had to pull the fan and shroud to do it. The AC lines aren't an issue.
Then I don't have to invest the $200-300 to replace the seal on the high pressure side and recharge the AC! Thanks Greg. Scott...
1 - 3 of 3 Posts
