1 - 10 of 10 Posts
05 silver stick
under the hood near the battery is a
black plastic box with a cover you pop off
look under the cover and it will give you the location
of the fuse you are looking for.
you will see a bunch of fuses and relays there.
there are also other fuses up under the dash on the drivers side
against the firewall
but I think the horn fuse is located under the hood
2005 and 2006 Scion xB
How do i know if its bad?
05 silver stick
figure out which one it is
pull it out and look at it
there is a thin wire inside it
if the wire is broken
the fuse is blown
you can also swap it with another fuse the same size to check it
the size is the number on it
1 - 10 of 10 Posts
