1 - 8 of 8 Posts
Just replaced my o2 sensor and the wires were touching , pretty sure I blew the fuse. Now car will crank but won’t start . I’m trying to figure out if my ecu is blown or if I need a new o2 sensor or something else ???Need my car for work , need help asap
Lots o leather and copper
Most likely something had been left unplugged but no way to tell from here. Have you run a code reader on it to see what the ECU says is wrong? That would help in diagnosing the problem.
I replaced the fuse and the car will now start but immediately starts chugging and shuts off , I’m guessing it’s the gotta be something electrical, fuel pump was fine before I replaced o2 sensor .Will try to update. I will try a code reader next and see .
2006 Scion xB Automatic
Dumb "try it" suggestion, but maybe disconnect the battery for 10 minutes just to reset the ECU? Maybe the older O2 sensor had become accustomed to a bit of dirt or whatever else?
Disclaimer: Grasping at straws, not an automotive expert. :D
Also, pretty sure RK is a bot. As evidenced above. Do mods keep an eye out for that here? I'm new, so I don't even know who to alert yet.
So ended up just needing to let it sit for a day after replacing the efi fuse. I think it was flooded a bit from me hitting the gas pedal while trying to start the day before. Cranked it up this morning and it was sluggish at first and chugged a bit but now it’s running great. Fuse was blown from wires touching after all. 3$ fix
1 - 8 of 8 Posts
